NewSistems Опубликовано 13 мая, 2017 Жалоба Поделиться Опубликовано 13 мая, 2017 Construction by DK7ZB for 2m, 6m and 10m The HB9CV-Beam is a 2-Element-Yagi with two driven elements and was introduced by Rudolf Baumgartner, HB9CV, in the 1950ies. The Beam is a coax-fed version of the ZL-Special. The reflector is fed 225° out of phase. The distance between the two elements is 1/8-Lambda (45°), with the two crossed phase lines of 180° results the 225°. It is astonishing that this antenna is not well known in many countries, the ARRL-Antenna-Book does not mention this type of antenna. Читать дальше Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
