News Опубликовано 8 августа, 2015 Жалоба Поделиться Опубликовано 8 августа, 2015 You are invited to participate in CW Open on 5 September.There are three separate contests, each judged and awarded, and winners are selected in ITU Regions 1, 2 and 3.Trophies are awarded to winners in each region; and plaques awarded to winners of HP, LP and QRP categories in each region.Session 1 is from 0000 to 0359Z; Session 2 is from 1200 to 1559Z; and Session 3 is from 2000 to 2359Z. A new log is used for each session.Bands: You may operate on one or more of 160, 80, 40, 20, 15 and 10 meters.Exchange: QSO number and name (example: 9 Joe); each session starts with number 1, again.Scoring: 1 point per QSO per band per session; 1 multiplier for first time you work that call per session. You get the same score for working local stations as for working DX, so try to work everyone you hear.Logging: N1MM, N1MM+, WriteLog, SD, and others (see www.cwops.org/cwopen.html) Logs must be submitted in electronic format. A customized log submission form for CW Open is available here:http://www.b4h.net/cwops/I hope to work you all in CW Open.73,Rob K6RBhttp://feeds.feedburner.com/~r/hfdx_news/~4/u3SIMUD6uFgЧитать дальше Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
