Универсальный синтезатор Si570/Si5351
Сообщений в теме: 86
#41
Tik
Tik
  • 4 сообщений
  • Позывной:YO8RFS
Hi Andrey,
Sorry for long delay to reply..... My  free time is very compresed . :(
Thank you for your solution..... I am modified and put your sugestions and now all is OK.
After  finalizing my project I want to put normal optical encoder....Now for testing  use a rest of the component  in surplus  an old project  mcHF SDR TRX.
I tested CAT interface. Work but only unisense.....DDS to PC work,  via USB com used for programming . PC to DDS comnd not work.I not tested with TX and RX pin comand of Arduino module. Question: For CAT mode need use RX/TX pin Arduino module , or work only USB com?
Thanks again, 73  from Tik, YO8RFS
#42
Relayer
Not understand what you mind under "PC to DDS". CAT support is limited to read current freq/mode from VFO and setup band/freq/mode form PC. This is ok for log software and simple rig control via USB
#43
Tik
Tik
  • 4 сообщений
  • Позывной:YO8RFS
Andrey, I tested software  with N1MM and MixW32...Read freq from VFO (DDS)  via USB port but not read setup /mode /frecv from PC.
Not understand happened.... USB com is ok. Any ideea?
#44
Relayer
No ideas. Now I haven't time for play with it. Firmware is open source - you can easy add support for extra CAT-command.
#45
Tik
Tik
  • 4 сообщений
  • Позывной:YO8RFS
Is ok, I check again my hardware, may be happy lucky men . Thank you and good luck Andrey!
73 from Tik, YO8RFS
#46
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Не хочет скетч компилиться...
In file included from C:\Documents and Settings\Лашов\Мои документы\Downloads\Syntez_Si5351_Si570-master\Syntez_Si5351_Si570-master\Syntez\Syntez.ino:36:0:
sketch\disp_ILI9341.h:27:58: fatal error: PDQ_GFX.h: No such file or directory
А там и правда такого файла нет
Нашел на гитхабе - но не в виде файла, а в виде кода. Сделал текстовым редактором файл PDQ_GFX.h - все равно его не видит.
#47
veso74
veso74
  • 6 сообщений
  • Позывной:LZ2WSG
  • LOC:KN34PC
RA4DB,
на адрес: https://github.com/a...on/PDQ_GFX_Libs
нажмите на зеленый прямоугольник (вверх, вправо: Clone or download), потом "Download ZIP".
Скачайте архив на свой компьютер, распакуйте файлы и скопируйте в My Documents\Arduino\libraries\
#48
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Попробовал. Еще хуже получилось
Arduino: 1.8.6 Hourly Build 2017/11/07 04:33 (Windows XP), Плата:"Arduino Nano, ATmega328P"
 #include <PDQ_GFX.h>        // PDQ: Core graphics library
compilation terminated.
exit status 1
Ошибка компиляции для платы Arduino Nano.
Неверная библиотека найдена в C:\Documents and Settings\Лашов\Мои документы\Arduino\libraries\PDQ_GFX_Libs: C:\Documents and Settings\Лашов\Мои документы\Arduino\libraries\PDQ_GFX_Libs
#49
veso74
veso74
  • 6 сообщений
  • Позывной:LZ2WSG
  • LOC:KN34PC
RA4DB, скопируйте содержание папки на "один уровень вверх".
  • Прикрепленный файл  lib.jpg   85,75К   Количество загрузок: 14
  • Прикрепленный файл  c.jpg   272,63К   Количество загрузок: 14
#50
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Танцы с бубном дали кое-какой результат. Теперь требует файл конфигурации
In file included from C:\Documents and Settings\Лашов\Мои документы\Downloads\Syntez_Si5351_Si570-master\Syntez_Si5351_Si570-master\Syntez\Syntez.ino:2:0:
PDQ_ILI9341.h:51: error: #error Oops! You need to #include "PDQ_ILI9341_config.h" (modified with your pin configuration and options) from your sketch before #include "PDQ_ILI9341.h".
Сделал по своему разумению:
Прописал в начале скетча
и положил файл конфига в папку Syntez.
Получил вот  такой ужас, в котором я не разберусь:
In file included from C:\Documents and Settings\Лашов\Мои документы\Downloads\Syntez_Si5351_Si570-master\Syntez_Si5351_Si570-master\Syntez\Syntez.ino:3:0:
C:\Documents and Settings\Лашов\Мои документы\Arduino\libraries\PDQ_ILI9341/PDQ_ILI9341.h: In static member function 'static void PDQ_ILI9341::begin()':
PDQ_ILI9341.h:628: error: 'SPI' was not declared in this scope
  SPI.begin();
PDQ_ILI9341.h:630: error: 'SPI_MODE0' was not declared in this scope
  SPI.setDataMode(SPI_MODE0);
PDQ_ILI9341.h:631: error: 'SPI_CLOCK_DIV2' was not declared in this scope
  SPI.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (full! speed!) [1 byte every 18 cycles]
#51
Relayer
Вам надо библиотеку PDQ_GFX установить. читайте мануалы как и куда устанавливаются библиотеки в ардуино. В кратце у вас в каталоге где все библиотеки должно быть два подкаталога - PDQ_GFX и PDQ_ILI9341
#52
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Их есть у меня
И вообще, везде, куда можно набросал эти две папки. Все равно требует конфиг, после копирования конфига пишет, что
  SPI.begin();
 и подсвечивает строку
FastPin<ILI9341_CS_PIN>::hi(); // CS <= HIGH (deselected, so no spurious data)
  • Прикрепленный файл  Ard.JPG   23,36К   Количество загрузок: 16
#53
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Идей,  я так понимаю, ни у кого нет?
#54
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Жалко, ну ладно. Будем считать  - гешефт не удался)) Буду искать другую схему синтезатора, а этот пока буду использовать в качестве подсветки - дисплей ярко так светит))
#55
Relayer
Файл конфига не нужен. ILI9341_CS_PIN и ILI9341_DC_PIN определены в disp_ILI9341.cpp. Вы прописали тип дисплея в cjfig.h? Там должно быть так:
//#define DISPLAY_LCD_1602
#define DISPLAY_TFT_ILI9341
#56
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
У меня вот так:
  • Прикрепленный файл  config.JPG   47,86К   Количество загрузок: 25
#57
IvanPetkov
IvanPetkov
  • 16 сообщений
Андрей, ты золотой. Это почти законченное строительство. Я отправляю фотографию.
Прикрепленный файл  IMG_1525.JPG   187,58К   Количество загрузок: 35
#58
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Так требует Ардуино IDE.
#59
Relayer
Поздравляю! Выглядит очень хорошо
Вы для начала попробуйте правильно установить библиотеки и скомпилировать примеры которые идут с ними. Когда все заработает тогда можно и к синтезу переходить. Не забывайте сгрузить свежую версию с гита
#60
RA4DB
RA4DB
  • 66 сообщений
  • Позывной:RA4DB
Библиотеки установлены, среда их видит. Тестовые скетчи компилируются, грузятся, работают.Рабочий скетч - отказывается.
  • Прикрепленный файл  Lib IDE.JPG   79,71К   Количество загрузок: 19
  • Прикрепленный файл  20180428_082621.jpg   576,24К   Количество загрузок: 17
